  • 141
    I came across this 2 1/2 years ago at a motel in BFW(the tool that is). Curious, I asked the maintenance man what he intended to do with it. Nothing he replied you can have it. I gave him a couple bills anyway.
    I'll put it to use this week.
    Re: 141
    What is it? Pipe die? Nice find for a few bucks.
    As an electrician, all I notice is the shoddy wiring.
      Re: 141
      It's for threading 2.5" through 4" pipe. New they are north of $2,500.
        Re: 141
        So the 4" pipe acts as a sleeve to guide the weight while you thread the 2.5" pipe?
        I do my share of threading pipe, but only 10' sticks of conduit on the ground.
          Re: 141
          It's a geared threader. The pipe is usually in a vise and you use something like a 300 with a drive shaft to power the threader. Some will also use a hand threader with an adapter but that is a bunch of work.
            Re: 141
            To run the 141 with a 700 you need a head that has a socket that fits over the lug in the threader (instead of the standard 12R head), using it is a bit of a work out. I used to have a drive shaft for the 300. For the life of me, I don't know where it is. I still have a soil puller for ty seal though.
              Re: 141
              Thanks for explaining. Wow, I wouldn't dream of hand threading anything that big.
                Re: 141
                takes a little more than 62 seconds to thread the big stuff.
                not sure if there is enough time in the day to make it a roundup event.
                  Re: 141
                  I had my 141 rebuilt to better than brand new and then only cut a dozen or so 4" threads with it. Now I have a 141, a new drive bar and my stands but I cannot find my drive shaft. It's an odd enough duck I doubt an employee walked off with it.
                    Re: 141
                    Cut a thread with it on some 3". I thought it turned out great.
                      Re: 141
                      That was a sweet deal. I lost ours when I loaned it out.
                        Re: 141
                        Guess you never threaded any ridgid conduit larger than 2" then.
                        Its for pipe sizes 2-1/2" up to 4".
                          Re: 141
                          make sure you have that 300 and your pipe vise anchored down and be using a dead mans switch/foot pedal. I've watched more than one set up twist and turn itself to death when it bound up and the idiot put a brick on the foot pedal 'cause he thought he had something that was more important that couldn't wait.
                            Re: 141
                            I don't have much to work with on this one. The second photo is the bathroom above. Supplies are in the wall, if exposed , I still wouldn't have enough room to spin a wrench.
