sum beach !!!
  • sum beach !!!
    Has anyone had a good experience trying to get a puck lock off? Sum beach , I lost t he darn keys to my truck and I heard those locks are almost pick proof.Any advice before I break a window, cut the divider back and remove the puck lock bracket from the door frames??
    Re: sum beach !!!
    Locksmith said he can't pick it but did Jimmy the front door so i can get into the cab.At least he saved my window.
      Re: sum beach !!!
      PM Gear Junkie. I think he can tell you how.
        Re: sum beach !!!
        Check your messages monster.
          Re: sum beach !!!
          Just sent one also . Think I taught Gear !
            Re: sum beach !!!
            Thank u
            sir!!!
              Re: sum beach !!!
              Thanks tool!!!
                Re: sum beach !!!
                  Re: sum beach !!!
                  I have an assortment of those locks. The puck can be soft metal or hard stainless. Doesn't really matter as the brass keyway is soft and easy to drill. Theres only I screw holding the cylinder in and 2 roll pins that engauge the lock.
                  Now if it has the cylindrical american, keyway, I've picked those with a locksmith tool made to duplicate the key. Pretty simple with the right tool. Hard to drill, easy to pick.
                  Did you get it open?
                  Rick.
                    Re: sum beach !!!
                    Rick.
                    Yea, it took me a while because the the whole assembly is at the bottom of the door towards the bumber.Even with an angle drill it was rough but I did get it.
                      Re: sum beach !!!
                      Drilled one of mine out last year when the brass key broke off up inside. Was a PITA because of the angle. I should have just ground off the 6 bolt heads and locked down to a bench vice to drill out the keyway.
