Hot Water Suggestion
  • Hot Water Suggestion
    Inherited a job with no pre planning. Pool house, detached, ALREADY built. 95% complete. Need hot water. Nothing pre plumbed for hot water.
    One lav, outdoor shower for pool and the washing of 3 big hairy dogs. No compromises, they want LOTS of hot water when needed. They thought a 6 gallon ariston 110v unit would work. No 220v available. I am running natural gas for pool so I can get gas where needed. I'm thinking a lower btu tankless outdoor installation.
    Any one have another suggestion?
    Thanks
    No space for traditional tank heater.
    Re: Hot Water Suggestion
    Sounds like a perfect scenario for a tankless.
      Originally posted by wookie View Post
      One lav, outdoor shower for pool and the washing of 3 big hairy dogs. No compromises, they want LOTS of hot water when needed. I'm thinking a lower btu tankless outdoor installation.
      Tankless, but install the maximum size you can. It will modulate and if they run over the max you can always say that's what they get for not planning. (it's not on you then).
        tankless or just tell the dogs to jump in the pool as needed.
          Install that tankless on the backside of the poolhouse (exterior). Out of site, doesn't need a lot of room.
          David
            David
            Also you do not want that tankless burning that chlorine rich air coming off of the pool
            it will it eat up the burner and the heat exchanger !
            JERRYMAC
            E-MAILJERRYMAC777@GMAIL.COM
            FIRE SPRINKLER CONTRACTOR,
            SINCE JAN. 1989
              150K gas unit ought to be big enough to run the shower, if gas is available. I wouldn't waste their money on a condensing unit since it will only be used intermittently. An electric tankless like the Eltron Steibel Tempra 20 will also work if you have the amps to run it.
                unless he's next to 3 mile island, electric tankless suck up power like crazy. they make a 20 gallon 2000 watt 120 volt tank heater that would be plenty and a cheap install if they can find the room for it.
                I have 1 customer with a small 1 bathroom condo that has an electric tankless. uses 6- 70 amp breakers and it just barely gets by.
                those undercounter electric point of use tankless heaters are another joke. nothing like a mist of an aereator using 240 volts at 30 amps. I piss faster and it comes out hotter than those units.
                  Thanks all!
                  It will be a Takagi TK-jr, a non condensing unit.
                  Pool not built yet, but huge backyard and tankless won't be affected by chlorine but good point to consider.
                  wookie
                    why did you decide on that particular model?
                      Thanks all!
                      wookie
                      Let us know all the colorful words they call you when you put that in
                      I've had nothing but trouble with the 'jr' model.
                        Been a couple of years since I've installed a Takagi. Have @ 24 Takagis installed, no issues. Hope it stays that way.
                          Top marks Jerrymac for being observant to this.......!!!!!!
