Expansion tanks
  • Expansion tanks
    I don't have much experience with them. Since our city water meters don't have check valves in them, there is not much need for them because the heated water can push back through the cold lines when the pressure builds (apparently even past the heat traps installed in the tank.)
    Of course we them in the systems with circ pumps and tankless.
    My question: is there a scenario where an old or faulty expansion tank can cause a knocking in the pipes when the hot water is turned on or when a circ pump is running? It is not water hammer and the knocking is about 2 beats/sec. Also, it is not loose pipes. And it is sporadic. It sounds localized near the ex.tank. Perhaps it could be the flap in the check valve slamming. The other time this occurred there wasn't a check valve,just a pressure regulating valve.
    Re: Expansion tanks
    Is the Ex. tank full of water ! rubber bladder blown out ?
      Re: Expansion tanks
      Two beats per second kinda' sounds like a flat washer loose and vibrating. Not sure that helps, but I have heard it before in weird situations.
      I don't think a faulty expansion tank would cause the sound when opening something.
        Re: Expansion tanks
        The tank I replaced today had 0 pressure, so yes, the bladder must have been leaking. I am still curious if that could be the cause of the knocking. I guess I will find out if the knocking stops. But, I still want to know why.
          Re: Expansion tanks
          I don't think it is a loose washer in this case. New addition (3 or 4 yrs), all washerless faucets and no outside faucets. There is a tankless water heater in the closet with the expansion tank.
            Re: Expansion tanks
            I'm getting confused. Are there check valves and/or a circulating pump in the system now?
              Re: Expansion tanks
              Both a check valve and a circulating pump.
                Re: Expansion tanks
                I've traced knocking sounds back to faulty water meters before.
                  Re: Expansion tanks
                  could be the check valve making noise. could be a bad pump cartridge.
                    Re: Expansion tanks
                    We had an issue with a chattering concealed water pipe on a remodel we did a few years ago. I was getting pretty worried about it because the stretch of pipe that was vibrating was concealed and finished over before the problem was discovered. We tried to isolate and solve the problem in different ways, but it wasn't until I spoke to a friend at the supply house who gave me a good tip that we found and fixed the problem.
                    We had installed a new Bradford/White water heater and the problem turned out to be a rubber washer which acted as a sort of heat trap in the cold inlet of the water heater. At just the right flow this washer would flutter and create a pipe chatter that resonated throughout the house. Pulling that factory installed heat trap and replacing it with an in-line spring check solved the problem.
                      Re: Expansion tanks
                      Originally posted by GreatLakesPlumber View Post
                      We had an issue with a chattering concealed water pipe on a remodel we did a few years ago. I was getting pretty worried about it because the stretch of pipe that was vibrating was concealed and finished over before the problem was discovered. We tried to isolate and solve the problem in different ways, but it wasn't until I spoke to a friend at the supply house that we found a fixed the problem.
                      thanks ,that's awesome Info. !
                        Re: Expansion tanks
                        we had a similar problem with rheem/ruud tanks that used the ceramic check balls. rattle rattle rattle at certain flows.
                          Re: Expansion tanks
                          OMG!!!! I swear, lawyers can be the most difficult people to work for sometimes (this homeowners profession).
                          I picked up another expansion tank and replaced the old one. The old one had completely lost its charge. I was still trying to parse out how it could cause the knocking sound. To me, the water forces inside a pipe can be downright mysterious what with eddies and cavatations (sp?) aspirations, diffused oxygen, heat, pressure, physics, etc.
                          Mind you, this owner told me the knocking only occurs when they use the hot water and it would always stop when he turned the water off to the water heater.
                          I had just decided to live with the mystery of why it happened -then he said," while your here, please check our toilet. It seems to run sometime.... I just shook my head in disbelief that I could be so stupid! Of course, it had to be the fill valve. And it was.
                          The lesson I learned- Listen attentively to the homeowner, then check everything no matter how many times they say "it can't be that".
                          Thanks for all your suggestions. Sorry to waste your time with this one.
                            Re: Expansion tanks
                            Can I just act like I'm listening attentively.
                              Re: Expansion tanks
                              Of course! That goes without saying.
