toto drake g max can't be installed back to back ???????????
  • toto drake g max can't be installed back to back ???????????
    Is this a fact ?????
    dont all toilets have to be at least 18" from the soil pipe on a cross tee or be connected by wyes on the pipe?
      I recently found back to back Kohler class five toilets in a 1980's home that were connected to a sanitary cross. When either toilet was flushed water would shoot up out of the other bowl about 5". I would expect the Totos to do the same.
        these are slab on grade homes built around 1958
          it requires either a double figure 6 a double figure 8 or a back to back comby.
          the figure fittings have a built in baffle.
            Pretty embarrassing when you snake a pan only to have it unload in the toilet behind. Yeah this was one big learning curve early days for this humble servant of the blocked drains brigade.
