LOW FLAME ON NATURAL GAS FIRE PIT ??
  • LOW FLAME ON NATURAL GAS FIRE PIT ??
    About 6 Years ago I installed a fire pit. did a presto lighter repair yesterday. Lite off and low flame ? When I can get back I'll disconnect ring and blow out with compressed air and put mano meter on unit. Any ideas appreciated,as always.
    The issue is either rusted and plugged gas jets as the fire ring is submerged.the better rings are made from stainless steel and dont rust.
    issue #2 is the underground pipe has filled with water and is preventing full flow.
    remove gas meter to allow free air flow and connect a shop vac to the riser before the fire ring. You have trapped water in the submerged fire ring pit.
    Rick.
      Thanks Rick awesome info AS USUAL
