Metal drains
  • Metal drains
    Does everyone outside of oklahoma use metal drain traps? I love plastic thin wall. I've seen a lot of pictures of all the metal. Just curious.
    Are you talking 17ga. chrome plated brass P-traps?
      What's the application?
      Residential kitchens here use PVC slip joint almost exclusively.
      Same w/ lavs unless exposed or commercial like a wall hung or pedestal.
      In service I always replace metal w/ PVC when possible.
      • GreatLakesPlumber
        GreatLakesPlumber commented
        Editing a comment
        Same here, Big Jim. The tubular PVC traps seem to seal up better and are impervious to corrosion, making them better over the long haul.
      Same here Big Jim.
      David
        Many commercial applications will require tubular brass, it will be in the job specs. Often this is for fire and smoke spread prevention. If plastic is allowed it generally has to be system 15 pvc.
