ummm...What the ???
  • ummm...What the ???
    Yes that's a gas line going up the down spout to a roof top furnace .
    It's all downhill from here
    At least the PVC "Shield" will protect it from damage!
      To me it was a somewhat cleaver way to hide black steel pipe. Too bad they didn't hang it parallel with the real downspout to the right.
      I had a job where the cable/ satellite lines were run from the roof 3 stories up, down the no hub roof drain lines into the garage and exited via a jim cap in the garage on an entire condo project. The only good thing about this was the homeowners could actually watch on live tv their building getting flooded.
      Rick.
        Should they be using black steel outside? Looks like lots of corrosion.
          Galvy for this Irishman.
            What was the Gasfitter thinking..........????????????
              I think it's brilliant. Obviously it's not being used for a downspout. Also, galvy for gas is mostly a Ca. thing. Most states galvy for gas is illegal, inside and out.
                I was kind of amazed myself.Not a bad idea,out here galvy on gas lines is a no go...as well with copper too.Except outside of cook county in the farms where there's well and septic with propane tanks .
                  Galvy is an approved material as far as the National Fuel gas code. I'm not clear why it is illegal in many places. Here all exterior gas piping is galvy and there is no corrosion that I can see. Copper is also an approved material but it is based on the content of Hydrogen Sulfide in the gas. Copper is pretty much exclusively used places like the UK and Europe - never heard of issues due to the use of copper in gas piping over there.
                    Got a call from a voice message from a customer yesterday, they were attempting to install a cold water supply to a refrigerator ice cube maker and used a self piercing valve. (Not legal here btw.) and they attached the self piercing valve to a gas line. We all know mistakes happen. Thankfully nobody was hurt.
                    • PLUMBER RICK
                      PLUMBER RICK commented
                      Editing a comment
                      Was the gas line copper?
                      I was at a job yesterday and noticed a patio stubout meant for an outdoor bbq. It had a gas valve then went to pvc and headed into the ground. No idea where it goes as the patio is small and covered in brick. Fortunatly the valve is off. No idea if the homeowner, handyman, or gardner might have attempted a planter sprinkler system or bbq. Looks like its been there for years.
                      Rick.
                    Yep. Copper. It's legal here for natural gas.
                      Because their are properties in the gas that cause the galvy to flake off and mess up gas controls,
                      think back to the days when they had run away burners,
                      which is why their has to be gas valve close at hand to shut off gas in case you can't get to the burner control ! also the same for copper on the West Coast
                      Preview
                      Jerry Mac
                      MAC SALES 777
                      SEWER EQUIPMENT SALES
                      jerryhodge@att.net
                        We have (had) a copper stub off of our gas meter that used to go to the back of the house for a grill. I found it buried when I had to re-do some drains for rainwater underground. It was about 15 feet long, just cut off and buried about a foot deep. A side shutoff was put on the meter, so I guess it was put there when the hosue was built in 1968. Thought about running a new line for the grill off the valve, but never got around to it and capped it off at the meter. It was all copper from the fitting on the meter, on.
                          Nice . Had one of those also. The HO was finishing off attic. He was drilling something and drilled through a black steel gas line. He said he thought he felt something hard but just kept at it. Fortunately that piece was in an unfinished area and I was able to fix it with a couple nipples and a union. Jeez
