Water Closet Drain to close To wall
  • Water Closet Drain to close To wall
    Here is the picture. I was wondering if my only option is to chip away the concrete and move on or if there is a easier way around this problem
    RYan Varga
    ryan, not only is the pipe too close, but there is no closet ring installed.
    the best choice is to cut the concrete and move the center line of the pipe to 12'' from the future finished wall. also make sure your flange will sit on top of the finish floor. it also has to bolt down and be properly secured.
