midget tubing cutter
  • midget tubing cutter
    I just got a 118 self feeding tubing cutter and i like spring idea it works great . it would de nice if they can adapt this to the other cutters
    To be politically correct, wouldn't that be a "vertically challenged" tubing cutter.
    Lorax
      Heh heh,
      I recently bought the spring loaded "baby cutter" also. (hasn't grown up to be a full sized cutter). While idea is was great it seems to take too long to cut tubing on its own. Its still a good gutter but I help it along by tightning the knob every other turn.
        it might take Little longer but if you have big fingers like me , to work the nob in a tighten spot this works grate
          I agree
          I agree it was a good idea but doesn't work that well. but that doesn't matter if you tighten it yourself it works the same as the old style.
