Are Rigid pipe threading dies interchangable
  • Are Rigid pipe threading dies interchangable
    Are Rigid pipe threading dies interchangable with all Rigid pipe threaders (both manual and powered). I'm looking at purchasing a Power Drive 700 and already have a manual Rigid threader with a few dies. Only need to use 1/2" and 3/4" dies.
    turbo, the 700 uses the larger type 12r die head. chanes are you have a 00- r die head (smaller dies). there is an adapter that will run the oo-r die head in the 700 machine. it's a model # 770.
    personally i would buy the 12-r dies to fit the 700 and go with the larger 12-r die head.
    if interested i have a #770 adapter that i've never used.
    the actual threading dies that fit the die head are interchangable between these die heads.
