propress sc - contour
  • propress sc - contour
    i was wondering just what the differance is between the propress fittings that do not have the green dot on them and the fittings that do have the green dots on them.
    tom
    the green dot is the newer propress fittings that have a little "notch". this will allow for the fitting to leak if not pressed. the older fttings with no dot could actually hold pressure if not crimped. then a little movement and you have a real flood.
    ps. the propress section on this forum will have alot more info.
