Pump for Laundry Sink
  • Pump for Laundry Sink
    I want to add a laundry sink in my basement but the discharge sewer pipe exits the basement about 5' off the floor through the basement wall.
    I know I can add a tank and pump to pump up to the sewer piping.
    What would be a good pump and tank to use in this application.
    I am thinking that it can go directly under the sink.
    Would a connection from the tank to the vent stack also be nessesary?
    All of the drain and venting piping is accessable right above the sink location.
    I can't personally reccomend it because I have never installed it, but this looks like a possible easy solution for you.
    the dog
      He's another source:
        Thanks for the info
          Macerating Toilets & Sinks
          Check out this site;
          I just finished the install on the SaniPro system into my basment wit a vanity & shower. No pit to dig, and no slab to crack. It ejects thru a 3/4" PVC max of 12' vertical and 120' run with gravity drop. Got mine from Ferguson on special order, check with them but a sink system only should be in the $200 range. Only note, plan to get speed clamps for the unit, the included ones are a joke.
            The zoeller link from plumbdog's post is probably the best way to go. It's really inexpensive and that little pump typically lasts ten to twenty-five years. I've seen quite a few of those around here in walgreens' and cvs' photo labs for their utility tub - which takes a lot of abuse! If it's good enough for that it oughta stand up to a washing machine for a good long while.
