manablock replaced with wisbro
  • manablock replaced with wisbro
    I have a Vanguard PEX manablock manifold system in my home. It is about six years old now. I have sheared off the key knob of two of the valves. I was wondering if it is possible to replace the manablock with Wisbro’s Pro Pex system. Use the PEX already run and just use the ProPex Rings and tool to make the connection to a ProPEX copper manifold.
    I wouldn't.
    I would not use pieces of one system on another. Wirsbo Aquapex is made to be used with expandable rings for their pex only and vise-versa with Vanguard and their rings. To do so may create more problems than you have now.
    One of the best lessons I learned from my father is when he did nothing to help me. I then learned to help my self.
      you could use a small section of wirsbro pex on the new manifod and then connect to the anguard pex with a transition type of coupling such as a watts shark bite fitting. these are approved for copper, pex, and cpvc. they work on an o-ring seal with stainless gripper teeth to keep from pulling apart. you could also use a brass coulping with a male fitting from each brand to connect to.
      why nt just use the same brand as the original? if you exercise the ball valves on a regular basis. 2 x a years. they will probably not seize up. true with any valve.
        Why don't you just call up Vanguard and tell them that your valves are breaking and you are not happy. They will send you out as many of the new valves as you ask for. They are fairly easy to install, and the new ones have larger plastic tabs that are harder to break. I've done this for quite a few customers.
          Rick, I'm somewhat surprised that you endorse the sharkbite fitting.
          I have used them many times with no problems at all. I first installed them in my own crawlspace about a year ago. I attached copper to pex and the seal is tight and will not let go...I have yanked on the pipes to try to cause a leak and they are dry as can be.
          I give the Sharkbite fittings two thumbs up!
            norcal, i have been a fan of sharkbite since it first came out. i keep a goodie bag of fittings in my truck, right next to my propress fittings
            still waiting for the 1'' fittings to come out
              Watts? I didn't know Watts made the Sharkbite line.
              I think that Cash Acme will want to know about this :-)
              Here's a brochure from Cash Acme about Sharkbite®.
              It does indicate that the 1" fittings are new but I did not
              find any indication of when they would be hitting the shelves.
              http://www.cashacme.com/SB_Quad406.pdf
              One application I thought these would be good for is testing.
              No more soldering test caps on your copper lines (small bore
              anyway), just pop a Sharkbite cap (End Stop they call them)
              on there and when testing is completed you can remove and
              reuse them.
                bob, thanks for the heads up. i'm sure i've stated cash acme in prior threads. on this one i blew it.
                maybe watts got some inquires and will kick start them into making something like this
                i too havn't seen any 1'' fittings. they were suppose to come out months after the original debut of the 1/2'' and 3/4''.
                i will inquire at the trade show this weekend.
                thanks bob.
                  It's a table saw, do you know where your fingers are?
                  http://www.powertoolinstitute.com/stream1.html
                  This reminded me of when my father-in-law was using his jointer and had his fingers hanging off the end. Evidently the pain and blood spattered on his saftey glasses and the wall was not a big enough clue because he did it again on the next pass.
                    I spoke with the Rep from Cash Acme at the PA/NJ PHCC Trade Show in Atlantic City last week. I didn't ask specifically but he never mentioned that the 1" were not available or would be out soon. He had plenty of them on display, at least a couple dozen that everyone was playing with.
                      The 1" Sharkbite fittings have been available for a while in Nevada.
