Fixing sump pump
  • Fixing sump pump
    Have a Ridgid SP500, needs a new Switch/Top Assembly. I see I can order the part... is it recomended that I have a repair person do the replacement or can I do this myself?
    Thanks.
    ddk
    i would replace it myself as the cost of the switch and labor is probably more than a whole new pump
    i looked at the part on the website and it appears that the switch is a whole assy. appears to be a do it yourself item.
      ridgid warranties that switch up to two years,and it is an easy fix.
      A fishing pole is the best cordless tool!
        i recently changed the switch assembly on my rigid pump, no problem, just keep it upright as the motor is filled with oil.
