Sump pump won't stop
  • Sump pump won't stop
    I've replaced a sump pump in my basement with one of the same make and model. However...the pump will not shut down when the water level drops. It has a diaphragm switch, and the troubleshooting material said (if the discharge pipe included a check valve, which it does) to drill a 3/16 hole in the pipe about two inches above the discharge connection. It still will not shut down. Anybody have an idea what I may be doing incorrectly?
    does the pump actually pump out the water and lower the level of the pit?
    the pump literature should give you the on and off levels of the pump.
    the 3/16'' hole is important as it prevents the pump from getting an air lock since a check valve is required and is insatlled.
