Hot Water Heater-Gray water?
  • Hot Water Heater-Gray water?
    I have drained my tank and I still get grayish water out of the sill cock. Any thoughts?
    Gray water
    If you are talking about the drain valve at the bottom of the water heater you should flush it out until it runs clear, if you are talking about an other point where you are getting gray water thats a different prob. FYI water heaters should be flushed at least once a year to get the sludge out of the bottom of the tank;[Nobody does it]. Lots of luck.
    "If all else fails, read the directions"
