RIDGID 1-7/8" Shop Vac Adaptor for 2-1/2"
  • RIDGID 1-7/8" Shop Vac Adaptor for 2-1/2"
    Hello,
    I just wanted to pass this quick and simple fix to everyone that has a Ridgid Shop Vac with 1-7/8" hose and accessories. After a week of getting very upset with Ridgid for not have a adaptors for the 1-7/8" hose I decided to just have a look in the plumbing department. After about 20 minutes of looking at the PVC and rubber fittings I found one that worked. Best part is it cost a grand total of .42 cents.
    You can view the information here;
    http://www.bedlamcreations.com/uploa...id_shopvac.jpg
    nicely done sir
    I bought the pro pack 1 7/8 and found out (no thanks to any ridgid literature online or on the box) that the intake is 2 1/2". Is that the model you have and if not is the intake different? I bought the 2 1/2 to 1 1/4" adapter hose from ridgid (like your pic) and plug the 2 1/2 end right into the intake. I had some extra 1 1/4" hose already so I have good movment and range when I hook up my dewalt sander and it works great. I tried to find a fitting in the plumbing section at HD and even asked the orange apron if they had large food grade tubing that might fit ("try a restaurant supply store") until my girlfriend threatened to leave me at the store overnight.
    Anyway, I wish I read your fix before scouring the net over the decision for hours and hours. nice pics too.
      Try this link and take your time looking around. Larger Home Depot stores have quite a selection. Take your Ridgid shop vac along and if what you just bought doesn't fit, you can return it right then and there.
      Hint: Carefully measure the inlet on the drum and then the hose adaptor for any hose(s) you are interested. I need to check the machines, but I bet they all have the same size drum opening and that all of the Ridgid (and most likely other brands) of hoses will work.
      http://www.ridgidparts.com/accessories/
      I have done some custom adaptors myself out of PVC fittings and pipe. If you have a good lathe and a 3 jaw chuck, you can really get into making your own fancy custom fittings.
        I have the Wall Mount Power Pak version. Which does have a 2-1/2" inlet. However that would require purchasing a 2-1/2" hose, accessories, etc. I leave my vac mounted on the wall in the garage unless I need to take it outside or in the house. The power pack version comes with 21' of hose. So instead of replacing all of the hose I just made that adapter, which works great on my table saw and miter saw. The extra 6' long 1-1/4" hose gives me a total of 27' of reach for using with hand tools or the car.
          How about 2 1/2 in hose to 1 7/8 accessories?
          I have the reverse problem. I bought a 4x ProHose for my WD 4550 but had to return it because there is only a single 1-7/8 in connector in the kit (which screws onto the hose and is supposed to connect the hose to the vac). That leaves no connector to connect to my 1-7/8 in accessories. I just sent an email asking Ridgid customer service if they sell the connector separately, but has anyone else come up with a solution for this problem?
          (I spent quite awhile at Home Depot in the PVC pipe section and didn't find anything that'd work).
