Newbie with a brand new TS 3650
  • Newbie with a brand new TS 3650
    I purchased a 3650 earlier this week, and in the process of assembly. My first question is how tight should the nuts be at the connecting of the lift to the legs? Should they be run down to the end of the thread? I will not be turning the saw upright until Saturday when I have some help.
    Thanks, Phil
    Re: Newbie with a brand new TS 3650
    Not sure I totally understand your question. I think what you're asking is how tight should the nuts on the legs be when you get around to lifting it? If that's it, they should definately be snugged up tight.
      Thanks, VASandy for your help.
      Phil
        Do not run them all the way up all you need is a full nut to make the lift work right.
        SSG, U.S. Army
        Retired
        K.I.S.S., R.T.F.M.
          Thanks TOD, for your help. I ran the nuts up tight, but the lift would not work. I backed them off 'til the lift worked.
          Phil
