Problem with 10 inch miter saw
  • Problem with 10 inch miter saw
    I have a Ridgid 10 inch miter saw. I beleive that the adjustments are off. It does not cut a straight line. I have the saw set at 0 degrees and set at 0 bevel. It still does not cut a straight line. What can I do to resolve this?
    Re: Problem with 10 inch miter saw
    First of all grab the manual
    Then have a l@@k at pages 15,16,17,18
    Hopefully that will solve your problem
    If you still need help after that come back and ask
    Good Luck
    Cheers! - Jim
