18 volt cordless circular saw problem
  • 18 volt cordless circular saw problem
    when I set the adjustment this to zero my blade is 2-3 degress off. how do i fix it?
    Re: 18 volt cordless circular saw problem
    I am looking at mine right now.
    There is a set screw that works as a stop for the blade angle adjustment. Set your saw at 0 and then snug the screw up to it. Dont forget to tighten the locknut.
      thanks forthe reply. when mine is set to 0 the plate is off a few degrees. using the adjustment screw to set the plate will cause the reading on the scale of the 2-4 degrees.
      Any other sugesstions?
