Makita LS1214FL or Bosch 5412L SCMS?
    Re: Makita LS1214FL or Bosch 5412L SCMS?
    Originally posted by NavyBuck View Post
    Well, I ended up getting the Makita, although I felt a strong pull for the Bosch. Boy you weren't kidding about the poor instruction manual! Now I have to figure out how to mount it on my (old style) MSUV. The holes on the saw are parallel front to back, but do not line up with any set of holes on the MSUV. I suppose I can drill the MSUV, make a base out of MDF and mount that to the MSUV or use the MSUV for something else and get the new MSUV with the sliding rails, which should work perfectly with the Makita. Thoughts?
    I drilled out a couple new holes in the MSUV. Just be careful. I didn't think it through completely and ended up with the holes a little too close to the rails. I had to flat a washer so that it would fit.
      NavyBuck
      You might like to download, print this and add it to the manual. I'm not sure what they supply in the way of a parts list, but this isn't bad.
      http://www.makita.com/assets_product...s/LS1214FL.pdf
