r213bna oiling
  • r213bna oiling
    On the nail gun it says to "oil daily", but the manual does not inform one how to do so. Can anyone help me?
    Re: r213bna oiling
    FP you put one or two drops of proper pneumatic oil into the male nipple on the end of the gun just before you hook the airline up.
    That's it, you should do this every time you use the gun.
    You should also bleed your compressor often as water will accumulate in the tank and could find it's way up the line and into your gun. I leave about 25 psi or so in the tank and crack the bleed valve just before I use the compressor.
    Hope this helps
    Cheers! - Jim
      Re: r213bna oiling
      Isn't the R213BNA an oil less brad nailer?
      ------- Henry Ford
        Re: r213bna oiling
        BD, yes you are correct - i was referring to the straight finish nailer. Thank you for the correction.
