3/8 all thread rod cuter
  • 3/8 all thread rod cuter
    i know some of you have one or more of these cutters . i have a one its a MCC and i cant fined new cutters .does any one know where i can get some
    Re: 3/8 all thread rod cuter
    I have same one bought at Graingers I think. Try there. I love that tool.
    Ridgid should make a allthread rod cutter for their Propress
      If Grainer doesn't have what you need you might call the factory and ask if they know where you can buy them in your area or maybe a national supplier.
      http://www.mccusainc.com/Contact-Us.htm (contact)
      http://www.mccusainc.com/Tools/Rod-Cutters.htm (about rod cutters)
      http://www.mccusainc.com/Tools/Threaded-Rod-Cutter.htm (also about rod cutters)
        rems makes a 3/8'' and 1/2'' cutter that fits the propress.
        the only issue i see is now you have a 3-4 hundred dollar cutter that is attached to a $2,500 tool. before you know it, it's missing or dropped
        i still like the mcc tool by itself.
          i did contact them and they gave me a distributor that i would need an account at .
          rick where do you get the cutters from ?
            one of my supply houses stock the cutters. i run into the rep every year at the trade show.
            have you tried to reverse the cutters from inside edge to outside edge
              yep i did a 1/2 a year ago . i cut a lot of rod and lone the tool
              i found a place that has them for $60 and just want to make sure that price is good . it will still be worth it for me to get them when I'm on a lift 45 ft in the air to cut the rod
