TS2400 Table Saw
  • TS2400 Table Saw
    I am having trouble raising and lowering the blade. Goes very hard. I blew out all the saw dust. Is there some gears that need to be cleaned or lubricated.
    Thanks for the info.
    Re: TS2400 Table Saw
    Just a question... you are loosening the blade elevation lock knob right?
    Cheers! - Jim
      yes, that is loose,
        Sorry, had to ask...
        The other most obvious thing is to make sure the elevating wheel is all the way "out", not "in" (or partially in) as when you tilt the blade.
        This is what the manual says ->
        Lubrication
        The saw motor bearings and gear case
        have been packed at the factory with
        proper lubricant and require no additional
        lubrication. The following parts should be
        oiled occasionally with SAE no. 20 or no.
        30 engine oil.
        1. Elevation screw threads. (First clean
        with a solvent recommended for gum
        and pitch removal).
        2. Bearing points in blade guard and miter
        gauge.
        Hope that helps, good luck
        Cheers! - Jim
          Thanks, I'll give that a try.
          Harlan
