13" Thickness Planer
  • 13" Thickness Planer
    My 13" Ridgid planer quit in the middle of planing a piece. The motor just lost power and stopped as if it had been unpluged. The power source was still good. I tried resetting the built-in breaker, but this did not help. The planer has very few hours of use on it. Looked at the brushes, they didn't looked to be excessively worn. No indication of power, such as a hum, etc. What should I try next?
    Re: 13" Thickness Planer
    run a meter on the cord to make sur the cord is not broken internly. also if you have had it less than 3 years(if you don't have the l.s.a.) take to a service center. sadly these are all about an hour from you....
    Baytown C & M Equip Co</B>
    508 Cedar Bayou Rd
    TEL: (281) 428-7045
    Fax: (281) 428-7391
    Miles From You = 53.2
    Community Motors, Inc</B>
    22159 Kent Dr
    New Caney
    TEL: (281) 354-8087
    Fax: (281) 354-8066
    Miles From You = 60.5
    Koehn Repair Shop</B>
    1125 E First St.
    TEL: (337) 463-3615
    Fax: (337) 463-7301
    Miles From You = 71.3
    Circle Saw Builder's Supply</B>
    2510 Ella Blvd
    TEL: (713) 864-8444
    Fax: (713) 864-6014
    Miles From You = 78.7
    9/11/01, never forget.
      Re: 13&quot; Thickness Planer
      This same thing happened to me, although it didn't quit mid-job. I used it to plane a few boards. Closed it up and set it aside. Next time I tried to use it... NOTHING happened. I too tried the breaker and what-not, verified the power source, etc. Drove me crazy for a week.
      Drove it 50 miles to the service center in Milwaukee, knowing full well it was gonna be something stupid... But I didn't want to open it up and risk my lifetime warranty.
      Sure enough, service guy had it fixed in about 10 minutes. Loose wire in the switch. Kind of scary if this a planer trend. Bad QA! Bad dog!
        WJ, I hadn't realized that Milwaukee has moved 22 miles closer to Madison.
