? on OL50135AL Compressor and 2 Framer Nailers
  • ? on OL50135AL Compressor and 2 Framer Nailers
    Does anyone use their OL50135AL twin stck compressor with two framing nailers-running continuously?
    Enough power or should I be looking at separate compressors or using a Paslode battery/gas cordless for one of the framers?
    Thanks, Lance
    Re: ? on OL50135AL Compressor and 2 Framer Nailers
    You shouldn't have a problem running two framers. Easiest way to be sure is to time how long the compressor runs per hour. If the units NEVER stops or runs 40 minutes for every 60, then it is time to go with a bigger tank. I have in-lined an extra tank between the compressor and a gun (an old-dead compressor) to have some extra storage capacity, but your twin-stack should be just fine, since it is an Oil-Lubed unit.
    If it was an oil-free/maintenance free, not a chance in hell I would run more than one gun at once.
