Makita LXT Impact Wrench
  • Makita LXT Impact Wrench
    I just came across this:
    http://www.makita.com/menu.php?pg=pr...det&tag=BTW450
    Not the prettiest looking thing is it?
    Huge torque though!
    Re: Makita LXT Impact Wrench
    Nice to see more competition. Good specs too.
      Looks very competitive to other models out there. It ain't pretty but it's no Hitachi either
        It doesn't look bad. Hitachis look hideous! I realize performance is more important than looks, but did I mention that Hitachis look hideous?!
          Sorry for this question but, what are the typical applications for a tool like this? Car wheels? What else? What size of nuts we are talking about?
          Best
          Ari
            Best
            Ari
            Automotive and heavy machinery. Use mine mostly for removing lug nuts....they zip off in under a second. You need about 200 ft-lbs for lug nuts....300 ft-lb for axle and brake fasteners.
            A lot of racer's bring these to small venues where air isn't readily available....vs. haul their own compressor. Lots of Autocross guys have these because they race in parking lots with no power of any kind.
              I don't know what Hitachi are thinking with those crazy green designer patterns. The tools are supposed to be pretty good, but wouldn't some of those grip designs leave an imprint on your hand?
                Best
                Ari
                They're great for screwing in any fastener. Because they give super quick "hits", it's a lot harder to cam out of a phillips screw. I've been giving serious consideration to buying the mini impact by Bosch. If only I won the lottery; these choices would be so much simpler.
                  that would be the 1/4 " impact not the 1/2"
                  i love my 18v dewalt
                    Is that the Dw059? I'd love to get one of those some time, but for me I probably wouldn't use it that often. Would be great for changing tires though!
                      Sceeter
                      For tire changing I would take a good look at this one. While you have a cord it cost less than cordless and runs circles around them.
                      http://www.dewalt.com/us/products/to...roductID=10452
                      Last edited by Woussko; 11-12-2007, 06:16 AM. Reason: I got to howling again and needed to fix this post
                        True good point, or an air-powered wrench. They are kings of torque!
                          Originally posted by Woussko View Post
                          Sceeter
                          By the time you haul out that extension cord I'll have all the lugs off with my cordless impact wrench. Like all cordless tools...it is about convenience. No cord to wind and unwind. No cord to get tangled under a tire.
                          In fact, impacts, are one area where cordless gives up very little to corded. You have more than enough torque...and enough power to change a dozen tires.
                            If you've already got the batteries you can get a bare tool impact wrench for quite cheaper than a corded. They really don't give that much up to corded, about 325ft-lbs vs 345ft-lbs. I've considered picking one up off ebay for changing and rotating tires. Otherwise I'd have no other use for one but I guess it could save me money if it means I will not put off until too late to rotate tires and wear them prematurely
                              ....Otherwise I'd have no other use for one but I guess it could save me money if it means I will not put off until too late to rotate tires and wear them prematurely
                              I must confess. That was the big draw for me. I'm very bad about rotating the tires. :-( With the impact I am much better about it. :-)
