Ridgid Table Saw TS3650 Belt Slips
  • Ridgid Table Saw TS3650 Belt Slips
    All-
    I have the Ridgid Table Saw, model TS3650 (contractor saw). Since assembling the saw the belt has stretched and now slips when I am cutting anything tougher than balsa wood (slight exageration on that). Before replacing the belt (and ruining that one too), I am trying to figure out if I set this thing up correctly. It appears that the weight of the motor is supposed to pull tension on the belt....but the belt quickly stretched and now is too slack.
    I wanted to see if anyone else had a similar problem and what they did about it.
    Any thoughts you have are much appreciated.
    Tom
    Re: Ridgid Table Saw TS3650 Belt Slips
    It sure sounds like you haven't properly mounted the motor or aligned the pulleys. I'd suggest you repeat the setup procedure again.
    ------- Henry Ford
      Check this link:
      http://www.ridgidforum.com/forum/showthread.php?t=14943
      It may have some tips for you
      Go
