Router Handle Removal
  • Router Handle Removal
    I'm wanting to mount my Router to a table top and I need to remove the handle. Any Idea on how to get to the bolt?
    Thanks,
    Jim
    Re: Router Handle Removal
    First off, which router?
    If it's the Ridgid, I removed mine (from the fixed base) a while back by drilling out the plastic plug (it seems to be epoxyed in there with something NASA should be using on the space shuttle tiles). Then you can get to the METRIC allen bolts. Comes out pretty easily, but leaves you with holes in your handles.
    Jack
    I've learned a lot from my past experiences.
    I've learned nothing from my passed experiences.
      The same question was posted some time ago, not long after the Ridgid router came out. As I recall, those caps just won't be pryed out for whatever reason and have to be drilled. Really too bad, as one would think that "handle-removal" should be a practical and easy move if mounting the router in a table. Who knows what lurks in the minds of the manufacturing engineers...
        Thanks guys, It is a Ridgid. I did try to pry the caps out and of course you know the results I got. Going after the drill now!!
        Jim
          Same here, I tried in vain to remove them from my base. Didn't want to drill out the handles so I just modified my home made table to fit with the handles.
