should i keep the drill or the battery?
  • should i keep the drill or the battery?
    of all my tools, the 12v RA impact driver is the only one for which i have only 1 battery (came as part or a combo kit). the 12v batteries are marked down from $53 to $29. the 12v 2 spd drill (r820011) is also marked down from 119 to 79. i bought a battery and the drill. do i keep the battery only, so now i have 2 batts. for the 12v impact, or do i keep the 2sp drill leaving me with 3 12v batts, another cordless drill and my 7th battery charger? i have 2 14.4v impact drivers and 2 18v hammerdrills. any suggestions, short of keeping everything, would be appreciated.
    Re: should i keep the drill or the battery?
    I bought the kit w. the free RA impact, 2batts. they do not last long I am constantly rotating but they fast charge 20-30 minutes. I use the drill wy more than the ra Impact. I would like a 3rd batt,not the compact one for the impact. I assume you bought the higher amp ones, the kit has small compact type. So keep 3, the 12v drill is very good,I think the older one I have is better,metal ring on clutch not plastic and the chuck seems better,I use it the most over my other cordless drills;12vMakita,18v&14.4vMilwalkee,18vRyobi[do not use that one much]
      Finer, I don't know about your original question, however could I sell you a couple of chargers? You seem a little short there......Ray
