Ridgid Planer
  • Ridgid Planer
    I have the Ridgid planer that I bought about three years ago. I like it very much, but when I lock down the heads with the adjustment wheel, and plane a board, the wheel on the adjustment rotates strongly backwards, generally about a half turn. Does this mean that the depth of cut is being reduced, and if so, is there an adjustment to fix this.
    Re: Ridgid Planer
    Pull off the thickness setting wheel, pull out the post lock lever and then adjust until it locks to your satisfaction. Easy to do.
    dj
