planer problem
  • planer problem
    i took to much on one pass with a 13" planer and soke came out of the motor housing and it then shut down. The reset swich was fine. Do Ineed a new motor or brushes?
    planer problem
    I took to much on one pass with a 13" planer and smoke started pouring out of the motor housing causing it to shut down. I checked the rest switch and that did nothing. Do you think i need a new motor or brushes?
      Re: planer problem
      You'll have to pull the brushes and see what they look like.Hope you didn't burn the motor. How deep was the pass?
