WTS2000L Tile Saw
  • WTS2000L Tile Saw
    Can the WTS2000L saw cut through concrete brick and retaining wall blocks? Has anyone use the saw in that capacity? I will be doing several projects this summer using the blocks insteadof tile. Thanks for your imput.
    Nicholas
    Re: WTS2000L Tile Saw
    i just bought a masonry blade for mine. plan to cut some pavers soon (probably next week or two). just need to wait for the weather in atlanta to get a little nicer. i'll let you know how it goes.
      I have used my wet saw for pavers with the regular tile blade works great. blade is still sharp for tile afterwards
        Has anyone ever had trouble powering up their WTS2000L?
        I have done a couple of bathrooms and kitchens with a new saw I purchased last fall. I had put it away for a week and pulled it back out today and it won't start up. I checked the power outlet, that is fine, and have hit the reset button, but nothing is working.
        Any advice?
          Did you reset both the GFI and the overload protector on the gear box?
