Router Question.
  • Router Question.
    I have the Rigid 2900 router, and am looking to outfit it with a nice edge guide. The one that I have my eye on is the Porter cable Micro-Adjustable edge guide. Does anyone know if this unit will make a proper fit on my router? or would there be the need for some manner of adaptation?
    Advanced thanks.
    ~Blessings~
    Nathan
    Re: Router Question.
    Nathan,
    I use a Porter-Cable guide with my R2900. It's not the micro-adjustable one (I'm not familiar with that), but the one that Home Depot carries. I believe it's just the basic Model 42160. I tried to look at the product on the Porter-Cable web site, but all I get is an error. In any case, they may be all the same basic size, which means it should be a perfect fit for the R2900.
    I hope this helps,
      Originally posted by CWSmith View Post
      Nathan,
      I hope this helps,
      Thanks CWS.
      I have attached a photo of the one that I looked at. Rockler is selling this one for $49.95. But I will take a look at the one you have, also.
      ~Blessings~
      Nathan
        Nathan,
        Well, unquestionably, the Rockler is far more complex (adjustable?) than the simple Porter-Cable basic edge guide that I have. I think my purchase at Home Depot was only about $15 or so. Basically it's little more than a cast aluminum edge guide with two rods that fit into the router's casting. No fine-tuning knobs or anything like that. So, I guess it all depends on your needs or requirements.
        I wish that the R2900 had a little more information supplied with it, but it does appear that certain features like the edge guide and router base mounting are designed to accept certain Porter-Cable accessories. That's a good thing, I think.
          Nathan,
          I've got one & it mates perfectly. When you get it, screw the shorter, smaller diameter rods (supplied) into the closer set of holes.
          Porter Cable # 42690.
          Rockler part # 12821.
            Originally posted by bigscore View Post
            Nathan,
            Thanks, Bigscore. That settles it for me .
            ~Blessings~
            Nathan
              Nathan,
              I've got a 25% off Rockler coupon. However it's only good at my local brick & mortar Rockler.
              Tried to see your location via your profile, but you didn't fill it in. If you happen to be in the Atlanta area, let me know & I'll e-mail it to you.
                Nathan,
                That's very kind of you (and I will definitely go back in and fill in my location info), but I live in Amherst, NY. Once again, though - very, very thougtful.
                Blessings,
                Nathan
                ~Blessings~
                Nathan
