3300 psi pressure washer
  • 3300 psi pressure washer
    Can you tell me why this pressure washer has two model numbers associated with it? I can't find any information on the Ridgid site regarding this.
    Thanks
    GB
    Re: 3300 psi pressure washer
    I found this one. Don't know anything about the model numbers though. Maybe that is the model number.
      http://www.ridgid.com/Tools/RD80763-...r/EN/index.htm
      It sure looks like there are 2 model numbers for the same machine. RD80763 / RD80964
      The attached file is the parts list and it has both of the numbers on page 1.
        I just purchased the 3300 tonight and assembled it. Assembly was very easy and I am impressed by how strong this unit appears.
        Can anyone tell me how it holds up under pressure [no pun intended].
        Does it do well? Any known issues?
        Is this the first time Ridgid has manufactured and marketed pressure washers?
        Ok, that is all for now.
        Please answer if you can!
        Curious Freddy
        Don't squabble with the chickens
        Instead, soar
        with the eagles
          You will find your correct model number both on your unit [under the motor on the frame] as well as on the outside of the box.
          Freddy
          Instead, soar
          with the eagles
            Thanks
            GB
            Funny you should mention that I tried a lot to find that out, finally got through the maze of buttons to push at customer service and found out that the 80964 is for california which has stronger emission regulations, it is that simple. Buschman
