ts3660 belt guard install
  • ts3660 belt guard install
    Hi
    I am nearing the end of the assembly of my table saw but do not understand how to install the belt guard. Am I supposed to install the washer on top of the nut that is on the studs the belt guard then another nut or am I supposed to remove the current nut put the washer on the stud then the belt guard and then the nut. the instructions do not say either way. please help
    Re: ts3660 belt guard install
    Originally posted by buddy View Post
    Hi
    I have the 3650 and I think they are the same. Just looked at it and it has nut, washer, guard, flanged nut. In other words don't take first nut off.
    Below from online instructions which differ (I think) from book.
    TO INSTALL THE BELT GUARD
    See Figure 33.
    Locate the following hardware:
    1 belt guard
    4 flanged hex nuts (M5 x .8)
    4 flat washers (M5.3 x 12 x 1)
    Lower the blade and remove the belt.
    Install a flat washer on each of the four motor studs.
    Open the belt guard by pushing down on the tab lock.
    Place the belt guard so that the large hole fits around the
    motor pulley. Insert the motor studs through the small
    holes of the belt guard.
    Using a flanged hex nut, tighten securely.
    Place the belt back on the motor and saw pulleys.
    Close the belt guard.
    Check the belt clearances on the guard by raising the
    saw blade to full height using the blade height adjusting
    handwheel.
    Check motor clearance by rotating the bevel adjusting
    handwheel until the indicator is set at 45˚.
