Using a Dado Blade with the TS2400LS
  • Using a Dado Blade with the TS2400LS
    Hi everyone,
    My name's Jim and I'm a newbie here. I have a question regarding using a dado set with the TS2400LS table saw. According to the manual, a dado set up to 13/16" can be used. The manual says to remove the inner washer and spacer, then to re-install the inner washer. Unless I am seriously missing something, The inner washer is fixed. From what I can tell, it is what you put your wrench on to hold the arbor while removing the nut. Any suggestions or advice is greatly appreciated!
