Two R4330 Questions
  • Two R4330 Questions
    I have two questions:
    When I tried to change the planer blades I found the wrench supplied with the planer is too thick. Is this normal? Do I have to go out and buy my own wrench?
    While using the planer, vibration must have loosened the screw holding the Indi-i-Cut assembly together. I've tried several ways of putting it back together but I can't quite get it aligned. Is there a trick?
