Fence... Page Title Module
  • Fence...
    Hi Folks:
    New here,getting rid of my old Sears table saw,how's the fence on the
    TS 2410 LS.
    Thanks
    Tim.
    Found the answer I needed in the posts..
    Thanks Chris....
    Re: Fence...
    hi welcome to the forum! i have the ts2400 (same saw just different stand) and i think the fence is very good it locks on good and is easily adjustable hope this helps
      Re: Fence...
      I've been using my ts2400 for 2 1/2 years. The fence was the major reason I went with the ts2400, and I've not been disappointed. As noted above is adjusts easily, but more importantly it holds its set up and is not easily knocked out of alignment. I think this fence is heads and shoulders above the fences on any of the comparable saws. You'll probably come to like the simple, but effective and easy to use micro adjust feature on the fence.
      Things that should be considered for up grading, modification on the ts2400 are: the blade, get or make a zci, an after market miter gauge. You'll want these if your doing fine woodworking. If you doing primarily framing, rough work, then its fine as delivered.
      Dick
