wet saw diamond blade replacement question
  • wet saw diamond blade replacement question
    I have the husky wet saw from home Depot. I did replace the stock blade with a quality diamond wet saw blade. The blade size is 7".
    I'm certain I'm no where near the end of the blade's useful life. this is a question for future reference....
    When/how can you determine when the blade is worn/used up and should be replaced?
    Cuts are smooth and I typically run a stone over the cut twice just to ensure no rough edges. I have used this blade to cut granite and porcelain tile.
    Cactus Man
