ridgid twin stack oil less
  • ridgid twin stack oil less
    My compressor runs but doesn't build up any pressure. It has run great up till know. My friends Ridgid is doing the same thing. His broke abou 2 mos. ago. They were both bought about two years ago. Any ideas what's happening and can they be fixed. Any local repair shops around this area? Thanks
    Re: ridgid twin stack oil less
    Could be a bad pressure regulator but the first thing I'd check is the drain valve. Make sure that it's closed all the way. To find a Ridgid Service Center near your, go here. It sounds like your problem may be covered under the 3 Year Warranty.
