Have any novel uses for a small shop compressor?
  • Have any novel uses for a small shop compressor?
    Was sitting in my wood shop, looking at the compressor, and wondered what else I can use it for besides nail & staple guns and blowing sawdust from one place to another or clearing A/C drain lines. I didn’t come up with much so I thought I’d throw it out for discussion and maybe get some ideas to utilize it more.
    Jim
    Re: Have any novel uses for a small shop compressor?
    hover craft for the kids
      I'd like to use mine for inflating my kiddie pool.
        Airing up tires.
          and air mattress
            Let's see, so far:
            No kids
            No kiiddie pools
            Tiires - have AAA
            Air mattress....hmmmm; sleeping/resting in the wood shop? Possible!
            WHat else?
            Jim
              Please post more info about the air compressor. Depending on what it can deliver in the way of compressed air there could be many things it would do for you. Please post the start / stop pressure, tank size, CFM delivery at XX PSI and such.
                make some air (steam train) type whisles.
                http://www.trainweb.org/riverview/whistle.html
                http://www.whistleman.com/html/whistleman_.html
                http://www.copperas.com/titanic/whistle.htm
                http://rjweisen.50megs.com
                http://www.nelsonslocomotive.com/Sha.../PlumbingX.htm
                (the ones in this link are wood toys)
                http://www.lackwood.com/shop/whistles/index.lasso
                  Get some linear or rotary pneumatic actuators and use them to power all kinds of stuff.
                  • Pop-up targets on a pistol or rifle range
                  • Halloween or other holiday yard displays
                  • 'Star Trek' style door openers that whoosh a sliding door open/closed (could be tripped by IR sensor like used on home alarm systems for total hands-free operation).
                  • Pneumatic powered can crusher
                    It's pretty entertaining to dry the dog with compressed air after a bath.
                    Baseball is wrong - man with four balls cannot walk.
                      I own a travel trailer and I live up north, where it gets a little chilly. Well I will use it to blow out my water lines when the cold hits.
                      I'll drain my water tank first, then I'll open up each faucet one at a time. I'll cup my hand around the end of the faucet (take out airrater before you blast) with the blower in my hand and blow out the lines.
                      I'll keep moving around until I think I got everything and no more god awful tasting RV antifreeze in my water lines. I have never had a frozen pipe this way, works great....
                        I use mine to blow out my lawn sprinkler system in the Fall. It's undersized with only a 20 Gal tank but it still gets it done, just takes longer doing a couple fill/dump cycles on each zone. Doesn't cost me anything to do it this way though.
                          blow gun (sharp pencil,foam ear plug,1/2" tubing or just putty and tubing)
                            Woussko,
                            The compressor specs are:
                            Porter Cable 150 PSI, 6 Gallon Pancake Compressor.
                            Model C2002
                            2.6 SCFM @ 90 PSI
                            Cut-In pressure 120 PSIG
                            Cut-Out pressure 90 PSIG
                            SCFM @ 40 PSIG 3.6
                            SCFM @ 90 PSIG 2.6
                            Jim
                              Blowing off the lawn mower after doing the lawn. Blowing sawdust off me after running the table saw for a while (need to do that less now that I've upgraded some.
