3300 PSI Pressure washer pump
  • 3300 PSI Pressure washer pump
    I just purchased the 3300 psi pressure washer and I just want to be clear about something. The manual says to remove the sticker from the pump oil plug. It says nothing about removing the little red plug, but the sticker says to remove the plug also. Do I remove this plug?
    Re: 3300 PSI Pressure washer pump
    The plug is a little red plug that fills in the hole where you removed the sticker (red bulbous part). you will see a hole when the plug is removed. just think of it as a giant pimple that you popped.
      DO NOT remove the red plug. just the sticker
