Ridgid 3300psi Pressure Washer Detergent Tank
  • Ridgid 3300psi Pressure Washer Detergent Tank
    Am I missing something, or is there no place to store a detergent tank on the Ridgid 3300 psi pressure washer? The 3000psi unit does have a place for the tank. I am struggling to spend $600 for the 3300 psi unit, but if it has no way to store the tank, that seems like another plus for the 3000 psi unit. Since I have never used a pressure washer, maybe I am dwelling too much on how to store a detergent bottle. Just how do you manage this when using the PW?
    - Phil
    Re: Ridgid 3300psi Pressure Washer Detergent Tank
    The 3300psi does not have or need a detergent tank, because it has a suction line which comes with the unit. One end connects to the intake side of the pump and the other end of the line is placed inside the detergent bottle. Very simple and it works fine.
      I understand the tube going into the detergent bottle, but how is the bottle stored? Does not appear there is a place for it on the PW. Do you have to sit the bottle on the ground next to the PW, and then move both the PW and bottle to get to another location?
      - Phil
        Yes!. You move the bottle as required.
