EB4424 Storage/mounting suggestions???
  • EB4424 Storage/mounting suggestions???
    Like many, I've got limited space in my garage workshop. Since I purchased it a few months ago, my Ridgid Oscillating Edge Belt / Spindle Sander (EB4424) has taken up residence on my workbench. But I need my workbench space back. Does anyone have any suggestions on a convenient yet space-saving way to store or mount the sander?
    Thanks in advance!
    -O&B
    Re: EB4424 Storage/mounting suggestions???
    i mounted it to a piece of 3/4" plywood. the plywod has two holes in it so i can hang it on the wall. my miter saw stand also has a piece of 3/4" plywood mounted to it, as does my miter saw and a couple of other tools. all i do to use a tool is clamp it to the plywood that's resident on the miter saw stand.
      Thanks Finer,
      So you actually hang the plywood with the EB4424 mounted to it on the wall? I like the idea of using the miter saw station - I have an MSUV with my miter saw mounted to it. But it would be easy to mount the miter saw to a piece of plywood and make it possible to use the stand with multiple tools: EB4424, bench grinder, miter saw, planer, etc. I hadn't thought about that!
      Thanks for the tip!
      -O&B
        I made rolling stands one 24" one 36" and a storage cabinet. All my portable machines are on the same size chunk of plywood and both stands have a cutout frame to hold all the tools, there are screws with wooden hold downs on each side to secure the tools. The little drill press has been replaced by a floor model and my EB4424 now resides in that spot.
          Thanks Wayne!
          I like the idea of mounting the various tools to the same size piece of plywood, thus having the ability to interchange them on to the same mobile base. Excellent idea!!!!
          I appreciate you posting the pics as well. Makes it a lot easier to visualize the idea!
          Thanks again!
          -O&B
