Router Combo
  • Router Combo
    Hi, I just purchased the RIDGID router combo kit. I also sent for and just received the edge guide and plunge depth adjustment extension. there were no instructions for installing the depth adjustment extension.
    before I screw it up, can someone who has done this help?
    thanks
    phil
    Re: Router Combo
    Sorry Phil,
    I didn't know a plunge depth extension was even available... much less needed! Perhaps you can post a picture of it or provide a description.
    I have the router combo and use it in a Rockler table. With the T-wrench that is provided, I find it easy to adjust the bit height from above the table. Likewise, I also find it fairly easy to reach under the table to make any adjustment from there... even though the adjustment is at the rear, with the way I have it mounted. So, I can't quite picture the value of the plunge depth extension.
      Re: Router Combo
      thanks for the reply, I really didn't know that it was available either but when I went to order the edge guide, it was listed as an accessory so I bought both of them just to have it.
      maybe someone from the company will look at and answer this.
      phil
        Re: Router Combo
        Phil,
        BTW, it's undoubtedly too late as you've already purchased the Ridgid edge guide, but the Porter-Cable edge guide that they stock at Home Depot, fits the R2900 perfectly. I believe I paid about $17 for mine.
          Re: Router Combo
          Ridgid is actually making their own edge guide for the router now?
