power padsaw
  • power padsaw
    Hi, I'm trying to find a saw I can use close in to a wall, I was wondering if anyone knows of a padsaw type tool that is powered ( preferably cordless)?, normal Jigsaws are tool bulky (wide) for this job.
    Cheers, TMA.
    Re: power padsaw
    Fein Multimaster?
    May help if you told us the application
      Re: power padsaw
      I'd like the ability to cut flood boards (~12mm softwood) and plasterboard if a suitable blade is available. nothing too thick, literally a padsaw type tool.
        Re: power padsaw
        im not sure what your talking about? they do make a toekick saw to cut flooring up next to cabinets. but im intellectially limited, so i may not be understanding correctly at all
          Re: power padsaw
          the toekick saw can be rented at your local rental center.
            Re: power padsaw
            Maybe 'Padsaw' is a UK term, What I need is a small reciprocating saw, about the size of a small jigsaw but with a blade offset to one side so I can get right into the edge of a wall.
              Re: power padsaw
              I think this saw can probably do what you are looking for with the 4 position clamp, although it is about average size for a recip saw. The cordless models also share the same blade clamp.
              http://www.dewalt.com/us/products/po...productID=8339
              Check the 5th image.
