Fence Accessories for TS2410LS Tablesaw?
  • Fence Accessories for TS2410LS Tablesaw?
    Hi,
    Does anyone know what type of bolts to use to attach accessories to the fence on the TS2410LS tablesaw? The slot on the fence I assume is for attaching things like featherboards and sacrificial fence material. I am also looking for advice on dado sets and zero clearance inserts for it.
    Regards,
    Todd
    Re: Fence Accessories for TS2410LS Tablesaw?
    Originally posted by tfiorille View Post
    Hi,
    Regards,
    Todd
    At least on the TS3650, there were 3 extra square head bolts that came for attaching things to the fence. I use rocker T-bolts, but file down the edges so they fit into the fence's groove. There is also a size of hex bolt that will work, but I don't know wnat it is.
    For a Dado set, I recommend a Freud SD206.
    For a ZCI, try rolling your own. Or a quick way is to pick up a ZCI when you order the Dado throat plate.
      Hi,
      Regards,
      Todd
      1/4" hex head bolt has the right head size to fit the TS2410 and keep it from turning. I have a T-Track kit from Rockler from like cpw and was going to file them down until I found out the 1/4" works.
      BTW, Woodcraft had a sale on a couple of knobs and bolts (woodpecker brand) that had the 1/4" bolts as well. I pickup it up for ~$8 if I remember correctly about 2 weeks ago.
      There are a couple of threads here on ZCI. I just made 8 blanks for my TS2410. Search for my name and see the thread plus some great advice from other members.
