Ridgid 3000 PSI pressure washer question
  • Ridgid 3000 PSI pressure washer question
    I just set this thing up. While it is off, if I hook up the water line to it and turn on the water, some comes out of the gun. If I pull the trigger it does come out faster. I would of expected with the trigger off no water comes out?
    Any ideas what I may be doing wrong?
    Re: Ridgid 3000 PSI pressure washer question
    I fired it up and the problem corrected itself. Now the water doesn't spray unless I depress the trigger.
    Thanks
      Actually, water does still flow through when unit is off. Also when it is on, some water still dribbles out at the end of of the gun. I guess I'll call Ridgid tommorow.
        I have a Karcher pressure washer that I bought several years ago and the manual says that there should be water flowing from the nozzle when it is off. In fact it says to wait for water to flow out before starting the motor.
        When seconds count, the police are only minutes away.
